I noticed that the color brightness of the pads of my LC6000 is much lower than the brightness of the pads of my SC6000, is this a hardware limitation specific to the LC6000 or is there a way to adjust this? It seems that the brightness of the LC6000 pads are dimmed to 50% or 60% instead of being 100% when active and 30% when inactive.
So it is not easy to know if the pads are activated or deactivated for example when I use the stems mode on the LC6000 pads.
On the Sc6000 the difference in brightness is much more obvious when they are activated / deactivated
geposted Sun 07 Apr 24 @ 4:29 pm
