For some reason since the last few updates, my list do not stay in the order as sorted. For instance I have my playlist in order by the BPM. Now whenever I navigate between the Mylists, the list are out of order again and I have to click on the BPM column to get it back sorted in order of the BMP to least to greatest. This was quite annoying last night while I was at my gig. Hopefully this can be resolved in the next update. Thanks guys, appreciate your help!
FYI under options i have Yes selectedto keep sort order so not sure while it is not staying as I sorted when i move through the playlist.
geposted Sun 07 Apr 24 @ 7:31 pm
right-click on the list and unselect "keep order".
This option means "this list's order is important and should override sorting", so the opposite of what you want
geposted Sun 07 Apr 24 @ 7:34 pm
ok thank you, so I assume I will have to uncheck that on all of my list LOL geez
geposted Sun 07 Apr 24 @ 7:38 pm
thank you very much that resolved the issue!
geposted Sun 07 Apr 24 @ 7:45 pm
Yes I have same an issue and I tried keep order but it didn't keep how I did it, has anyone solved the problem
Tnx
Tnx
geposted Tue 23 Apr 24 @ 8:54 pm
If your files are stored on different drives, try the early access build from
https://www.virtualdj.com/download/build.html
geposted Wed 24 Apr 24 @ 7:32 am
Tnx
Tnx
I can't make it not work, like shown in this video
But yes, like Adion says, there is indeed a new early access release thar has a fix for when tracks are form different drives
geposted Wed 24 Apr 24 @ 2:08 pm
