Topic: 'extra.db' purpose?
mpuschPRO InfinityMember since 2011
Hello - I have one more question that I can't figure out.
What is the new 'extra.db' file used for? Am I correct in assuming it needs to be backed up?
Thanks!
geposted Mon 08 Apr 24 @ 4:11 am
It's the Linked tracks database, the meta data for anything specifically linked is held there.
geposted Mon 08 Apr 24 @ 4:52 am
Perfect!
If I could make a suggestion - maybe call this links.db instead of extras.db? Not a huge issue but may avoid some confusion in the future.
Thank you :)
geposted Mon 08 Apr 24 @ 4:36 pm
Well, this db stores the links information for now, but it's purpose is to store some other data as well.
So, it doesn't make sense to name it "links.db" either.
It stores EXTRA information that's not stored inside database.xml
That's all the average user should know, and frankly he/she should not bother about the naming either :)
geposted Tue 09 Apr 24 @ 9:03 am
