Hi Guys,
I'm currently having issues with trying to make my Numark FX work on windows 11 .
I was having some issues, noticing if I used a cheap soundcard, the headphones function would work occasionally and then spontaneously cutting off. Rebooting it seemed to help. I would use the the onboard soundcard as headphones and the soundcard as master.
I have a gig coming up and have updated to a better soundcard: M Audio Solo. (yeah, on a budget) and now cant get the headphones function working at all.
Any Help muchly appreciated. (using the onboard Nurmark FX soundcard output isn't an option)
Many thanks in advance
geposted Wed 10 Apr 24 @ 6:32 am
It should be a matter op simple mix and match.
VDJ sees it all as output channels, and simply sends the desired output type to any channels you setup
I often use this config when recording videos for YT
The master out goes to my external soundcard at my desk, which is connected to my main monitors
The headphones out goes to the laptop output, which will then often have headphones connected if needed
And the master then also goes out to the "virtual cable" which is really an internal driver that lets the recording software pickup the master output directly
geposted Wed 10 Apr 24 @ 6:50 am
Duplicate post. The earlier one is here:
https://www.virtualdj.com/forums/258001/General_Discussion/No_Headphone_outlet_on_Numark_FX_and_M_Audio_Solo_SoundCard.html
geposted Wed 10 Apr 24 @ 10:38 am
