I'm using VirtualDJ on a Windows 11 laptop which has an NVIDIA RTX A3000 GPU. This GPU is relatively new and has 12GB of VRAM, but I'm finding that my Stems 2.0 conversions are very slow (seem to be using CPU).
I tried checking the fixStems setting in VDJ and I tried setting VDJ to use the high-performance GPU in the NVIDIA control panel, but it didn't work.
How do I fix this?
How do I fix this?
geposted Thu 18 Apr 24 @ 3:29 pm
Try to select stemsGPU in options manually, and make sure 'don't use gpu' in stemsFix is not selected
geposted Thu 18 Apr 24 @ 3:50 pm
