Hello,
I have a new controller Pioneer ddj-Flx10
and I can't get a playable sound from this part
it leaks, cracks, interrupts... the laptop should have enough power (i9-13900HX 64GB RTX4060 Win -11) drivers, firmware, everything checked 10 times
Has anyone had the same problem or a solution
Thank you and kind regards
geposted Sat 04 May 24 @ 10:09 am
since you do not mention it did you follow this setup guide?
http://www.virtualdj.com/manuals/hardware/pioneer/ddjflx10/setup.html
geposted Sat 04 May 24 @ 2:47 pm
