In build 8124 when attempting to select script in an action pane, of either custom button or the controller mapper, ....
If the selection includes a query with "?" then the cursor jumps/moves to the top of the pane, NOT allowing for the intended selection to be made.
Note this occurs then one is selecting script that one needs to scroll down to view,
and thus dependent on pane and script size, to show the issue.
Summary:
If one needs to scroll down to portion of script in an action pane, then one can NOT select the intended script if it also, contains a query.
(selecting with the intent to copy and paste)
8095 works as expected
Summary:
geposted Fri 10 May 24 @ 7:07 pm
