I’ve done 3 two-hour shows using Virtual DJ and Live365 for 7 years. My Netgear router uses 270 Mbps. During shows, Virtual DJ covers the Auto DJ signal underneath.
Since last Wednesday at the times of the live shows, a little of both streams at the same time, in & out (3-5 seconds each).
Any idea how Virtual DJ gets overcome by 365Live Auto DJ suddenly now? Local server, weather, modem or what? Thanks any help given.
geposted Mon 20 May 24 @ 3:49 pm
Can you connect to the Live server without stopping the auto DJ first?
If so, maybe you had a temporary network glitch, and VirtualDJ auto reconnected as soon as possible
VirtualDJ will try reconnect when there is a small dropout
geposted Mon 20 May 24 @ 3:51 pm
