Hi
I hope your doing great! :)
ALLEN & HEATH XONE: K2
How do you Map the faders to the correct decks, please?
Thanks for your help :)
geposted Mon 20 May 24 @ 4:11 pm
DazWazCharlieCaz wrote :
Hi
by default if will follow active deck if no deck is specified.
But you can explicitly set deck in the mapper scripts, by adding deck X to the logic where X is the deck you want to trigger
For example :
deck left play
deck 1 play
geposted Mon 20 May 24 @ 4:13 pm
