Hello, the new Pioneer Opus Quad has a feature called smooth echo that automatically enables an echo when you perform certain tasks, for example when you use the crossfader. It can even only enable in certain use cases so that it's only really enabled when doing a smooth echo type transition.
The feature is explained here: https://youtu.be/D78Yt2VIB8g?si=zBaIzkv3oh4IFhEw&t=981
This is automatic and works easier than enabling the echo manually each time this transition type is desired. It would be really cool to use it in VirtualDJ via a controller.
Is there a custom function programmable for VirtualDJ to achieve this? Or maybe even a way to do it already?
geposted Thu 23 May 24 @ 11:20 am
check out red bullet point #7 on this page of the Virtual DJ manual
http://www.virtualdj.com/manuals/virtualdj/interface/mixer/audio.html
geposted Thu 23 May 24 @ 12:22 pm
