In files with variable BPMs, I've noticed that the saved loops don't activate at the correct start point.
VirtualDJ clearly knows where the loop is supposed to start, since the loop marker is where I saved it at. Just activating the loop activates it at different spots.
Here is an example.
Here is an example.
geposted Sun 26 May 24 @ 10:31 pm
Will be fixed in the next update
geposted Mon 27 May 24 @ 10:34 am
Awesome, looking forward to it, thanks.
geposted Tue 28 May 24 @ 4:03 am
