I have stored my library in my OneDrive folder (OneDrive\DJ Name\Media\Music folder) that I keep saved offline to my local drive because most of the gigs I have lack internet or lack good internet. I would love to sync it to a backup laptop, POIs and all, but the laptop has a different username folder (it was setup with a local account, then switched to MS account for my business.) I thought CloudDrive was going to be the solution, but found it not only uploaded a duplicate copy of the music in the App\VirtualDJ folder, but also failed to upload most of my tracks (it uploaded ~3400 of around ~10,000.)
I then decided to just sync selected lists, so I created a list in CloudDrive, searched my local library to drag and drop tracks, but when I click on that folder, it doesn't give me any sync options, only showing Rename, Delete, Add subfolder, and Properties.
Am I using this wrong? Is there a better option? Am I running into bugs?
geposted Fri 31 May 24 @ 8:49 pm
If the list is in the cloud, there's nothing to sync. It's there already. Create it locally, then it will give you sync options.
geposted Fri 31 May 24 @ 10:17 pm
