I have VDJ installed on a windows 10 laptop works fine if I drag a karaoke file to the karaoke to the karaoke side window all ok so far. When I click on the karaoke file it shows a small cog wheel on the windows 10 laptop this allows me to enter the name. Sadly this doesnt happen on the windows 11 pc. When I click the karaoke track in the karaoke side list it does not displaythe cog wheel so I cant enter the singers name.
I just wondered if anyone is using a windows 11 laptop for karaoke and has the same trouble?
Thanks in advance.
Thanks in advance.
geposted Sun 02 Jun 24 @ 6:33 pm
just tested on windows 11 the cog appears when you highlight the file (click it) you dragged over there.
geposted Sun 02 Jun 24 @ 7:53 pm
Thanks for the quick reply it looks like my windows 11 has possibly got corrupted many thanks for your help.
geposted Sun 02 Jun 24 @ 11:13 pm
