I am looking at how a Zoom feed can be pushed into VDJ for outward broadcast onto a radio server (not RMPT) on a Windows 11 PC, I know this is something that can be done on a Mac with additional software so I am just putting out feelers for if this can be done on PC and if so how and what additional software is required.
I have already tried voicemeeter and although I can get VDJ to work when I try to configure Zoom if then conflicts with VDJ and causes echo and distortion which is not acceptable in a live broadcast.
Any suggestions welcome.
Spec of the machine are:
Windows 11 Pro
Ver 10.0.22631 Build 22631
AMD Ryzen 9 6900HX
32 GB RAM
Windows 11 Pro
AMD Ryzen 9 6900HX
32 GB RAM
geposted Wed 05 Jun 24 @ 5:08 pm
Depends a bit on your soundcard(s).
virtual cable to route back the Zoom sound output as line-in in VirtualDJ might be a good start
https://vb-audio.com/Cable/
geposted Wed 05 Jun 24 @ 5:40 pm
I will give that a try, so far most options have not been successful but if this work it will be great. Thank you
geposted Wed 05 Jun 24 @ 9:44 pm
