When hovering over my set Hot Cues in the Pads section, the Tooltip used to display the text I had entered for each Hot Cue. Now when I hover over set Hot Cues the Tooltip displays "PAD HOT CUE". Is there a setting I can change which will enable the text I have entered for each Hot Cue to be displayed in the Tooltip when I hover over it?
Thanks in advance.
Thanks in advance.
geposted Thu 06 Jun 24 @ 6:35 am
Are you using the default skin, and are you using the default hotcues pad page?
geposted Thu 06 Jun 24 @ 6:50 am
Hi Adion,
Thanks for your reply.
Yes Im using the Default - Pro skin and I havent changed any PADS settings so I can only assume they are at default
geposted Thu 06 Jun 24 @ 6:55 am
Hi, I have the exact same problem. I believe it happened just after I upgraded to Virtual DJ build 8184. Prior to that, it was working fine. Any insight would be greatly appreciated. Thanks!
geposted Sat 08 Jun 24 @ 6:23 pm
It's fixed for next update
geposted Sat 08 Jun 24 @ 10:07 pm
