Hi,
I have several midi devices for light. With VDJ 2023 I was able to ignore them. Now even if I setup a custom device with "ignore" VDJ 2024 open them ALL and I was unable to use my setup.
How can I ignore them now?
Thank you.
Sascha
Thank you.
Sascha
geposted Thu 06 Jun 24 @ 6:25 pm
This is how it looks like in the old version. I was able to disable the midi device
![](/img/407370/6509/image001.jpg)
geposted Fri 07 Jun 24 @ 6:20 am
Should still be the same
geposted Fri 07 Jun 24 @ 6:40 am
Unfortunately not. I double check it.
Restore to the old version: Only Ports are open, that are not disabled
VDJ2024: All Ports are open.
I used a dedicated tool, to see which ports are in use.
Maybe only a hidden setting to disable it? And the update routine did to takeover this setting? I read the manual for MIDI and could to find any "Disable" function
geposted Fri 07 Jun 24 @ 7:05 am
So here are the screens in VDJ2024. The Bome MIDI Translator 1 is
- Not visible in the overview (1)
- In missing controller you can select it (2)
- No possibility to disable it (3)
![](/img/407378/88203/image001-2.jpg)
![](/img/407379/45787/image002.jpg)
![](/img/407380/83683/image003.jpg)
geposted Fri 07 Jun 24 @ 8:23 am
