Hi Guys, I've got a Problem with my VirtualDJ. I've got a new Laptop and have installed die newest Version of VirtualDJ (2024 b8184 PC). Now I can't use it like before. When I type a letter in the Browser (not in the Search Field), it will be typed automatically in the Search Field. It makes no difference if I set the Option "browserSearchByFirstLetter" on or off. It will always type in the Search Field. Is this a Bug?
geposted Fri 07 Jun 24 @ 11:44 pm
keyboard mapping, unmapped key entry [bottom of the list] delete that entry [clear the action box]
geposted Fri 07 Jun 24 @ 11:47 pm
Yeah, it works! You're the best. Thanks a lot
geposted Sat 08 Jun 24 @ 8:06 am
