djdad wrote :
Reloop told us ETA is end of July to beginning of August, but some stores may have it a bit later (everything moves slower during that time) . But be sure, VirtualDJ support will be there on time.
geposted Sat 06 Jul 24 @ 11:46 am
kradcliffe wrote :
Yeey ... have my mixtour pro in my hands here .. cant wait to get going on VDJ as well!!
At the moment on the DjayPro App, but cant wait for VDJ to support this sweet unit!
any ETA for the mapping/support?
geposted Mon 15 Jul 24 @ 8:23 am
Congratulations, =D
do you also have the cracking noises when you press on the left side at the top.
geposted Tue 16 Jul 24 @ 10:19 am
DjMagg0 wrote :
Congratulations, =D
Hahahaha ... YES.. but on the right side .. Like an extra hidden button... if i push on the side of unit, if gives a mechanical "click" . It is just the plastic casing. All, dont worry, the build quality is pretty solid, but not 100%
so far, happy .. loaded with features, will take a bit of time to master it.. For me, first time working with Djay Pro .. so that is part of the issue. Waiting eagerly for VDJ mapping. Will come.. bit of patience .. LoL
geposted Tue 16 Jul 24 @ 2:05 pm
EARLY ACCESS BUILD 8267 (2024-07-23) - Support for Reloop Mixtour Pro
Selected as best answer geposted Tue 23 Jul 24 @ 7:00 am
Does anybody know if the Laidback Luke 'signature features' (undocumented key combos demonstrated in this vid https://youtu.be/pz_gJaWQWF8?si=PfQKXLlkm6FRYSq7&t=395 ) are included in the default VDJ mapping?
It would be nice if they were, obviously with VDJ being so flexible I could probably work most of them out myself, but if they could be there by default that would be amazing...
I have mine on order, looks like it will be September time when mine arrives.
geposted Tue 23 Jul 24 @ 11:50 pm
We have included any (signature or not) feature we could find. So yes, those are included as well.
Now if it happens that we missed something (with all that layering) we can always update the factory default mapper if it comes to our attention.
PS: Here's the basic explanation of the features included:
https://www.virtualdj.com/manuals/hardware/reloop/mixtourpro/controls.html
geposted Wed 24 Jul 24 @ 6:48 am
The VirtualDJ team always goes the extra mile as usual, thank you so much! @PhantomDeeJay
geposted Fri 26 Jul 24 @ 2:09 pm
Super thank you very much.
Only I found out that I can not use the Cue Mix, I can not get through the knob on Main.
In the sound settings, the master output is at the back: Master Out L & _
not from a right output.
Build 8263 already supports the controller.
geposted Mon 29 Jul 24 @ 9:42 pm
Cue Mix should be fixed and working on the next update.
geposted Mon 29 Jul 24 @ 11:32 pm
I was pretty interested in this controller but ended up with a FLX10 instead :) Oh well.....
geposted Tue 30 Jul 24 @ 7:34 am
can the reloop mixtour pro be used at the same time as cdjs aswell, similar to using cdjs with a traktor x1 ?
geposted Fri 30 Aug 24 @ 12:17 pm
Of course it can.
geposted Fri 30 Aug 24 @ 12:20 pm
Is there any way to shorten the loop like in the laidback luke video?
https://youtu.be/pz_gJaWQWF8?t=524
Mode and browse just moves the beat over in my software.
geposted Mon 04 Nov 24 @ 4:19 am
Could be added, but in the meantime you can use MODE + buttons Nr.6 & 7 https://www.virtualdj.com/manuals/hardware/reloop/mixtourpro/controls.html
geposted Mon 04 Nov 24 @ 6:28 am
