I use an external hard disk to store the songs, when I create new virtual folders or filters the data is saved in the VDJ folder in my documents folder of the computer and not in the VDJ folder inside the portable disk, The problem is when I use another computer this data does not transfer I need to transfer it manually, is there a solution that defines all the activities Will they be created on the relevant disk and not in the My Documents folder of the computer?
![](/img/408096/77548/Screenshot 2024-06-17 161822.png)
geposted Mon 17 Jun 24 @ 1:20 pm
