Topic: Vinyl/Slip button on Rane 4
jmurph71PRO SubscriberMember since 2022
On Rane 4 controller, holding shift and Slip button activates vinyl mode for scratching and to deactivate you hold shift and Slip button again. I would like the led button to blink on Deck 1 or Deck 2 when vinyl mode is activated and turn off when vinyl mode is turned off. Is there a way to do this? Thanks
geposted Thu 20 Jun 24 @ 1:00 am
might not work, but you can try. Locate vinyl_mode in the mapper (you can search at the bottom left)
Change the action to vinyl_mode ? blink & vinyl_mode : off & vinyl_mode
Often there is a LED_VINYL_MODE in the mapper specifically for lights where you would write the action for the lights, but i dont see that in this mapper
geposted Thu 20 Jun 24 @ 2:24 am
The "vinyl mode" led exists on the SHIFTED layer on Rane Four.
This means, that even if you change the LED to blink, you will only be able to see it blinking when you press (and hold) the SHIFT button. The LED in question is SHIFT_LED_SLIP
You can change it to vinyl_mode ? blink : off
Most likely you don't want that. Most likely you want to see the "SLIP" led blink when vinyl mode is active.
It can be done, but a question arises: How the button should behave whn slip mode is active ?
Assuming you want a "combo", change the LED_SLIP key to slip_mode ? on : vinyl_mode ? blink : off
geposted Thu 20 Jun 24 @ 7:55 am
That worked. Thank you
geposted Thu 27 Jun 24 @ 8:46 pm
