Hello
I seem to having a bit of a problem . I've been changing the deck BPM readout to show as 1 decimal place (due to my pitch fader length) by going into the XML files and changing the BPMex to BPM. (so it shows as 128.3 instead of 128.35) However when i come to do the BPM readout for the vertical mode all i get is an error saying impossible to open skin Default: vertical
Is there anyway i can get this fixed ?
Incase anyone asks my hardware is
Apple MacBook Air M2 with 8GB RAM(Main DJ laptop)
HP FS1002-na Windows 10 laptop 16GB RAM with i5 10th Gen Processor Power (Music Prep laptop)
Pioneer DDJ SR2 Controller
geposted Thu 20 Jun 24 @ 7:07 pm
Where do you find the XML Files to change? I would like to change it to only be one decimal.
geposted Sun 28 Jul 24 @ 4:09 pm
