There are some stuff which is possible to do in Rekordbox while preparing USB sticks that I have not found in VDJ (yet)
For example, to add an auto-loop in the end of track.
Today I use VDJ to prepare my USB sticks.
My question is if there is a problem to let rekordbox access the mp3 files which VDJ use?
geposted Sun 23 Jun 24 @ 9:29 pm
Have you tried to enable the setting keepPlayingPastEnd ?
It should allow you to set a Loop after the end of the Track, not sure if this is exported to a Pioneer USB stick though
geposted Mon 24 Jun 24 @ 12:03 pm
I would love to be able to do everything in VDJ because that's the only software I want to use.
It's not a very big deal, on the other hand, to lose some functions, but still...
geposted Mon 24 Jun 24 @ 12:58 pm
So did my suggestion above work as expected ?
If so, what else do you miss ?
geposted Mon 24 Jun 24 @ 2:03 pm
Dad, my wish was that I could set a loop during the end part of the track and when track reach that position, a loop is automatically started, not need any action from my side.
(And of course that it gets exported in the CDJ export function)
So, for example a 4-beat loop to give me time to mix in another track, for tracks with very abrupt or short stops...
I don't see what 'KeepPlayingPastEnd" has to do with it?
geposted Mon 24 Jun 24 @ 3:53 pm
Easy fix with Poi Editor.
Check the Picture below.
My tip is to change the color to red for an example in the end loop, or green to the intro loop ;)
Just type in Loop 4 , 8 or how long or short you want the loop into macro action.
geposted Tue 25 Jun 24 @ 10:15 am
You don't even need an action POI, you can just modify your existing saved loop and check the 'Auto-Trigger' check box
geposted Tue 25 Jun 24 @ 10:21 am
Thanks. Good advice.
Does it gets exported during CDJ export aswell?
geposted Tue 25 Jun 24 @ 10:25 am
Not at the moment, but we'll check if it can be added
geposted Tue 25 Jun 24 @ 10:37 am
Great, Adion. Would be supercool if possible
geposted Tue 25 Jun 24 @ 12:56 pm
What checkbox?
Please do tell or show us more about it..
geposted Tue 25 Jun 24 @ 9:07 pm
geposted Tue 25 Jun 24 @ 10:13 pm
Wow !
That was something that I have missed totally.
Thank you Guru User ;)
geposted Wed 26 Jun 24 @ 11:51 am
Hi
I tested to create a saved loop and check ”auto trig” and then created a CDJ export with the hope it should auto trig also in my CDJ’s. But it does not.
Would this be something you can add perhaps?
geposted Wed 03 Jul 24 @ 5:16 pm
They answered already ;)
geposted Sat 06 Jul 24 @ 6:39 am
