Topic: How to map specific Fx?
apedjPRO InfinityMember since 2010
I want VOCAL ECHO mapped to a specific pad.
deck left padfx "????"
ThankS!
geposted Tue 25 Jun 24 @ 9:13 pm
pads already imply the deck from the definition, unless you want a rightdeck pad to call a leftdeck fx then a deck specifier isn't needed.
padfx echo 'stemfx:vocal'
geposted Tue 25 Jun 24 @ 9:42 pm
Stemfx:vocal is what I needed to know thanks!!
geposted Tue 25 Jun 24 @ 10:11 pm
Not working at all. :/
I tried with and without the left/right modifier because I'm recalling these Fx from an LPD8 (for reference the other pads are mapped to stem control and they all work)
geposted Tue 25 Jun 24 @ 10:13 pm
check what's happening then
effect_show_gui vocals echo & padfx echo 'stemfx:vocal'
geposted Wed 26 Jun 24 @ 12:21 am
I see it works but the GUI under pads wasn't showing it's activated.
geposted Wed 26 Jun 24 @ 4:13 pm
So the effect I want is the one under the Voc Echo under pads, the echo your mapping gave me just echos without cutting incoming lyrics off. Any idea? Thanks!
geposted Wed 26 Jun 24 @ 4:33 pm
NM.. found it on Pad Editor. :)
geposted Wed 26 Jun 24 @ 7:14 pm
