Hello everyone, I'm enjoing EZremix since months.
From last week, stems knobs on channels 3 and 4 are still working but the classic EQ on 1 and 2 are not anymore.
Someone have same experience?
Updated to the last version VDJ and Rane Four firmware
Thank you
Thank you
geposted Mon 01 Jul 24 @ 9:00 am
Use SHIFT+PFL button(s) to toggle between stems and EQ mode of operation now.
Manual will get updated as well
geposted Mon 01 Jul 24 @ 11:30 am
I will try, thank you
geposted Mon 01 Jul 24 @ 12:17 pm
Also make sure to set "eqModeDual" in settings to "None"
geposted Mon 01 Jul 24 @ 12:20 pm
For me it is the same, since Rane updated to 1.7.0.8 firmware version, the classic EQ in dual mode is not working anymore.
geposted Tue 02 Jul 24 @ 7:28 am
user28835295 wrote :
For me it is the same, since Rane updated to 1.7.0.8 firmware version, the classic EQ in dual mode is not working anymore. Anybody with this issue?? Even I opened a support request and nobody is answering me. Pitiful...
geposted Tue 02 Jul 24 @ 12:59 pm
this is not working... anyway I do not understand why we must set "eqModeDual" to "None" if this is a feature of Virtual DJ that I want to use...
geposted Tue 02 Jul 24 @ 1:02 pm
geposted Tue 02 Jul 24 @ 4:20 pm
Nothing helped: since last Rane 4 firmware update, no way to make Eq knobs to work in any eqmode, except of course the "frequency"
geposted Wed 03 Jul 24 @ 4:10 pm
Please try the latest EA version, with the latest FACTORY DEFAULT mapper.
Then, use SHIFT+PFL to toggle each deck between Frequency and Stems
geposted Wed 03 Jul 24 @ 4:12 pm
It didn't work anyway :(
Also, it's not the way EZremix normally works, if I must switch by pressing pfl each time, I would use Serato which has the same function and all the rest works stable
geposted Thu 04 Jul 24 @ 7:26 am
EZRemix is just a mode of "Stems on EQ knobs"
So, it doesn't have a "normal" way of operation other than substituting frequency with stems on the EQ knobs.
From what you're saying, it seems that you don't want the "new" way of dealing with stems, but the old one (using inner channels for EQ and outer channels for stems on channels 1/2).
If that's the case, since you didn't make it clear, then yes, current implementation does not support that.
The ability to use the old way (with dual EQ mode) will come in the next update as we revised the mapping further.
However, next time, please try to be as clear as possible on what you want and what doesn't work for you.
All this time, personally I thought that stems on EQ didn't work at all for you, which obviously is not the case.
geposted Thu 04 Jul 24 @ 8:09 am
Sorry, but I think you are wrong, because I tried everyday possible to make it works and I didn't find the way.
You can check the link below were I tried to activate it with Shift+PFL and nothing happens. If I disable EZremix or EQModern, then EQ Classic starts to work, but when I push shif+PFL, EQModern is activated automatically and there is no way to go back to classic EQ.
https://share.icloud.com/photos/0433eo8r8oR1gvYd7wXQwonlA
Please, could you help us?
geposted Fri 05 Jul 24 @ 10:11 am
Sorry, but I think you are wrong, because I tried every possible way to make it works and I didn't find the way.
geposted Fri 05 Jul 24 @ 11:23 am
Looks like eqModeDual is not set to 'None', since you have both outer and inner channels controlling the same deck?
geposted Fri 05 Jul 24 @ 11:35 am
I attached the configuration, as I said before, the initial set up is "eqModeDUal= None" and "eqMode= Frequency" when I press Shift+PFL automatically EQModern is activated on channels 3 and 4, and classic EQ is not working, you can see how it is moving classic knobs on interface if you move the knobs (physical) on channel 1 or 2 but this is not affecting any frequency, if I move the physical knobs on channels 3 and 4, I can see how eqStems are moving on the interface and eqStems works as expected but this is not happening with classics ones. After that if I push shift+PFL again, and nothing happens, I cannot go back to "eqMode= Frequency".
For me it is ok if it works as Serato do right now, pressing Shift+PFL, but I cannot get to make it work like Serato with any configuration, I can assure you that I tried every configuration available, I'm telecommunication engineer, with this I mean that I have the ability to configure the system as you are suggesting.
Thanks so much for your support.
Please, let me ask you something, I have a couple of colleagues that has Rane Four and have the same issue, so did you test with a physical Rane Four unit this configuration?
geposted Fri 05 Jul 24 @ 2:38 pm
And you are using the factory default Mapping ?
Also, please confirm from Settings->LICENSES tab - at the very bottom - you get VirtualDJ build 8241.2068
Can you please test with the 4 Decks layout skin and confirm that using SHIFT+PFL is toggling between Frequency and Stems PER Channel on the skin ?
geposted Fri 05 Jul 24 @ 3:03 pm
Yes, I'm using factory default mapping, you can see a screenshot attached.
The version I have running is 8241.2068, you can check it attached.
I just tested the 4 Decks layout skin and happened the same. I attached screenshots of this. You will see a initial configuration as Disable (classic EQ) and another screenshot after press Shift+PFL and you will see that it changed to EQModern, after that, anything is working as expected, because in this configuration "4 Decks layout skin", I cannot use EQStem and Classic EQ are not working... I think something is not mapped properly.
geposted Fri 05 Jul 24 @ 3:22 pm
Ok, we have found the issue. We will provide a hotfix ASAP.
geposted Fri 05 Jul 24 @ 5:49 pm
😍 Thanks so much!!! You are the best!!
geposted Fri 05 Jul 24 @ 6:08 pm
