Is there a work around for a holding query, removing the stutter behavior for a hotcue?
when a cue exists, with settings hotcueMode: stutter, the cue behaves correctly with the script:
but with a holding query.. the stutter behavior becomes effectively, same as settings hotcueMode: "Play"
(the above ^ removes the stutter setting behavior)
Is there a workaround to still allow for stutter behavior with either a holding or doubleclick query?
PS
I guess this could be useful if wanted only some hotcues to be stutter and some with play behavior.
(ie to set stutter/play behavior per hotcue)
hotcue 1
holding ? nothing : hot_cue 1
PS
geposted Mon 01 Jul 24 @ 11:52 pm
I can't see it working, stutter type scripts already have an up/down element to them, and holding doesn't play nice with up/down.
geposted Tue 02 Jul 24 @ 2:06 am
