I need a script to Master FX to turn on reverb upon startup
geposted Tue 02 Jul 24 @ 2:03 am
It's how you would switch any fx, but first you specify the deck.
read up on
effect_active
read up on
effect_active
geposted Tue 02 Jul 24 @ 3:54 am
No deck for this. I want the reverb switched on the master out as VDJ loads up. I already have it set but I must make it active every time I start VDJ. Also would this be placed in the head of the skin xml file?
geposted Tue 02 Jul 24 @ 9:23 pm
deck master is a deck. And you could bake it into a skin but much easier to include it in keyboard oninint mapping
geposted Tue 02 Jul 24 @ 9:55 pm
No.
Open "controllers" and edit the keyboard mapper.
Find the "ONINIT" key and enter deck master effect_active 'reverb' on
Thanks so much, both of you. I am still learning VDJ and having moved over from Serato 6 months ago.
geposted Tue 02 Jul 24 @ 10:13 pm
