I'd like to add a number of selected songs from search results to either sidelist/automix/karaoke using a keyboard shortcut.
I couldn't find a matching script command yet. Can someone please point me to the correct script command?
I'm looking for a command to add selected songs to …
(a) the currently active side view panel, no matter which one it is
(b) a dedicated side view panel (either one of the above) and bring it upfront (activate and set focus to it)
So, the first command would be rather generic (something like: "add to active sideview panel") while the second command would be more specific (something similar to: "add to automix panel").
Your answer is appreciated.
geposted Wed 03 Jul 24 @ 2:45 pm
You might check sidelist_add and automix_add_next.
Not perfect, but I guess they will be useful.
geposted Wed 03 Jul 24 @ 3:02 pm
also playlist_add
for (a) you could query the sideview focus, then call the right script to add to that list [note how we deal with list shortcuts]
as for (b) there's probably enough here for you to figure it out, but you can call a list into focus by name
sideview automix
shortcuts you need the list path.
sideview automix ? playlist_add : sideview sidelist ? sidelist_add : sideview karaoke ? karaoke_add : sideview sampler ? : sideview remixes ? : sideview_title & param_cast & add_to_list & sideview +1 & sideview -1
sideview automix
geposted Wed 03 Jul 24 @ 3:54 pm
Excellent!! Thanks a lot, guys, for helping me out on this!
geposted Thu 04 Jul 24 @ 6:30 pm
I think this can also be achieved as follows: playlist_clear & browser_gotofolder "your folder" & playlist_load. Instead of the actual folder name (I used a dummy "your folder" here), you can also use an integer like 4 to go to the 4th virtual/favorite folder.
geposted Sat 03 Aug 24 @ 2:12 pm
