have 2 windows tablets (dell fully loaded)
want to build a twin tablet (tablets will be in horizontal set up )and mixer setup
only want a single deck skin for each tablet
i,m useless at designing skins so any help or direction to a single vdj skin would be helpful
geposted Thu 04 Jul 24 @ 11:51 am
Hi
You can design your own with the tools in this topic.
https://www.virtualdj.com/forums/214132/VirtualDJ_Skins/Skin_Builder.html?page=1
The links may be unavailable but you can use wayback machine for the links or pm me if it's not against the rules.
I'm also a home user & have created some minimalist single & multiple decks for studio use & tape loops. I'll be posting a user guide video with examples in that topic within 48 hours or less. (There wont be any copy cat themes resembling or styled on hardware or other brands dj software )
I was in a similar position to you but i'm so pleased that I learned to craft my own as so many interfaces are incompatible with my workflow.
You only need the tools & a text editor. I use notepad++ Windows 11
geposted Thu 04 Jul 24 @ 2:19 pm
