Is there any way to allow VDJ to create m3u files if someone enables legacy support? It would be awfully nice to have that option again.
geposted Thu 18 Jul 24 @ 2:49 am
Go to settings and type in legacy ......
geposted Thu 18 Jul 24 @ 10:15 am
Yes that shows it visibly, however you can't do things like right click > create anymore.
geposted Wed 24 Jul 24 @ 10:35 pm
You can right click a list and export it to a m3u file
geposted Thu 25 Jul 24 @ 6:39 am
It's not the export functionality that I am not mentioning here, it's the ability to create an empty m3u list directly in the UI. That is no longer available with the recent changes.
geposted 7 days ago @ 2:27 am
No, creating new m3u files has deliberately been removed in VDJ2024 to only have one list type
So now VDJ reads existing ones, and it also creates copies of lists to m3us if you set that in the settings
geposted 6 days ago @ 5:39 pm
Actually forgot about this, but using 'create local list' on the 'M3U Playlists' root folder already creates a new playlist.
geposted 3 days ago @ 6:48 am
