I'm trying to learn about scratch DNA for lowkey parties without a controller.
I'm learning to make my own DNA's. The manual shows a save button in the lower right of the editor, but there is nothing there on my screen.
Also, is there a way to make my scratches takeover the entire deck audio (but still Slip)? As is, scratches overlap with the deck more like a send effect (both the track and scratch are equally audible).
V2024 b8225 Windows 11
geposted Fri 19 Jul 24 @ 4:15 pm
see the fx gui for over button, Slip will rely in slip mode.
Save isn't needed, you make changes that's it, the old has been replaced with the new.
If I was QA I'd request tweaks/improvements to this interface.
geposted Fri 19 Jul 24 @ 4:47 pm
Thank you Locodog.
If I'm understanding you right, I should be able to hit ALT 2x to open the keyboard layout, hit my binded key to open the SCRATCHDNA Editor, hit the scratch I want to edit and edit it.
The problem is that it is NOT saved when I do this. I select/open the scratch I want to edit, make changes in the editor, close the editor, BUT the scratch reverts to what it was. The changes are not saved.
Currently I have to reopen the settings, controller (keyboard) editor, edit the scratch, save it, close all windows, check it and repeat which takes a lot of extra clicks and time.
geposted Sun 21 Jul 24 @ 7:43 pm
I see what you mean now, yeah I'd call this a bug.
geposted Sun 21 Jul 24 @ 7:58 pm
Currently save is only there when editing from a pad page. Otherwise you indeed have to copy paste the script yourself
geposted Wed 24 Jul 24 @ 2:32 pm
