Is anyone using this controller? I have it set for stems EQ, using the outer bank (3/4) for stems. I need help because I can't get the inner (1/2) filter pots to apply filters to the output. Right now, the filter pot on channel 1 applies filter to both decks, and the one on channel 2 does nothing. The conventional EQ works fine on both 1 & 2. Frustrating...
geposted Mon 29 Jul 24 @ 7:37 pm
Have a look at your mapping to see if filter is set correctly.
geposted Mon 29 Jul 24 @ 8:01 pm
Don't change anything in Mapping for EQ or Filter.
Read Nr.4 from here .. https://www.virtualdj.com/manuals/hardware/roland/dj707m/layout/mixer.html
Which means that you cannot really use the 5 knobs full "Stems" EQ mode, you need to use the EZRemix or the ModernEQ.
geposted Mon 29 Jul 24 @ 8:18 pm
Looks the same:
/Users/ronaldlavoie/Desktop/Screenshot 2024-07-29 at 17.44.41.png
geposted Mon 29 Jul 24 @ 9:48 pm
Thanks. I just tried all EQ modes (including disabled), and the behaviour is the same: Ch 1 filter pot affects decks 1 & 2. Ch 2 filter pot does nothing. Could there be another setting that's causing this?
geposted Mon 29 Jul 24 @ 10:15 pm
The problem described in OP still occurs, regardless of EQ settings. And it does not occur with Serato.
geposted Wed 31 Jul 24 @ 9:02 pm
And your Audio setup is as per the Manual ?
https://virtualdj.com/manuals/hardware/roland/dj707m/setup.html
geposted Thu 01 Aug 24 @ 2:38 am
Filter on Roland 707m is Hardware effect . You must setting in menu on roland .
https://www.roland.com/global/support/by_product/dj-707m/owners_manuals/bd741f80-c5ed-47de-b7a1-afab08cac07b/
geposted Fri 02 Aug 24 @ 3:06 pm
