In the app above the crossfader, there is a button that says Mix FX, where I can select Echo and then when I fade from Deck A to B or vice versa, it will do the echo FX and fade out gradually.....how do I use this feature on a hardware controller such as the Inpulse 300 MK2? I don't have that button on there. I can manually enable it using a Pad button, but I kinda like having that Mix FX turned on automatically and when I crossfade it just does it.
geposted Thu 01 Aug 24 @ 8:17 pm
your oninit key mapping for your device, change from
to
headphone_mix 0%
to
headphone_mix 0% & effect_mixfx "echo" & effect_mixfx_activate
geposted Thu 01 Aug 24 @ 9:02 pm
So this will enable it every time on startup, but if I want to turn it off I can just click the button. Thanks!
geposted Fri 02 Aug 24 @ 4:19 pm
