A second independent browser.
geposted Wed 07 Aug 24 @ 10:01 am
Nothing. It is already the best DJ program by a large margin
That of course doesn't mean that it can't be improved :)
geposted Wed 07 Aug 24 @ 11:48 am
I'm looking forward to the day when VDJ gets the ability to automatically analyse unsteady tempos, and to either fit the grid to the music (like DJay Pro) or fit the music to the grid (like Ableton Live).
A sequencer for the sampler would be useful, and the ability to organise pad banks.
Being able to search/sort in the skin browser and/or have them optionally listed as text.
More versatile text plugin i.e. ability to use more than one instance. Not just static or horizontal scrolling.
Ability to use URL based overlays on streams for floating emotes etc.
geposted Wed 07 Aug 24 @ 12:04 pm
From what I have read from being on the forum for many years .....
Better colour waveforms reflecting frequencies
More "coloured" sound output (although available through VST plugins)
Ability to update tag/DB info directly in the browser
Better beatgridding (covered by @groovin above)
Presets for columns depending on the view (history/list etc)
Personally the only things for me are as follows:
Custom button access on the remote app
The ability to make the text in the search box changeable as it's fixed and sometimes too small
Updated skinning tools so custom skins can be made with little or no scripting experience
A more "modular" browser experience.
On another note the customer support from the VDJ staff is on another level and no other company I have dealt with comes even close to that.
geposted Wed 07 Aug 24 @ 12:25 pm
I agree the search box and the text inside it doesn't increase along with the rest of the browser text and icons when changing the text size with the + and - buttons.
I've got a large screen here, and sometimes I will resize VDJ to half width so I can see another window at the same time. I will then use the + button to increase text and icon size so I can read the track names.
The problem is, the search box and text doesn't follow.
geposted Wed 07 Aug 24 @ 1:28 pm
- More streamlined settings configuration (like settings groups "Scratch DJ", "cue behaviour", "playback behaviour", etc).
In my DJ friend circle, the number 1 real problem persons had with VirtualDJ was how difficult it was to get it setup to their taste. Even for myself, just to get to a basic configuration level that I felt confident about took weeks if not months (while weaving in regular life), and I'm still discovering new stuff there.
Most DJs I interact with unfortunately just want something that works how they expect with minimum fiddling, and comparably to the other software offerings out there. - More controls over font sizes in skins
This is probably doable with some skin edits, but it would be good if it was adjustable without that (and with maybe the skin either resizing itself accordingly or the text scrolling if too large for the container element). The browser has that functionality and it is really a thing I appreciate. Personally, it is too hard to read the text in the decks/above the browser for the default skin.
geposted Mon 19 Aug 24 @ 3:06 pm
Multi screen
geposted Mon 19 Aug 24 @ 3:27 pm
GKAudiO DJ wrote :
Multi screen
What exactly do you mean by multi screen ??
geposted Mon 19 Aug 24 @ 3:47 pm
