is there a way to switch between eq types from Stem to EZremix with out going to the laptop. I want to have a button or a script when I swich from 2 deck ( Stem) to 4 Deck Ezremix. I can do it with a key command and also on my controller. Thank You
geposted Thu 08 Aug 24 @ 8:58 pm
setting eqMode Stems ? setting eqMode EZRemix : setting eqMode Stems
geposted Thu 08 Aug 24 @ 9:42 pm
both all 5 stems and EZRemix are both stems.. and maybe assume you also wish to change from the Dual mode (say outer eqs as freq and inner as full 5 stems), to all 4 decks being EZRemix.
If that is the case, something like this would work mapped to a keystroke:
eq_mode EZRemix ? eq_mode stems & setting eqModeDual Inner : eq_mode EZRemix & setting eqModeDual None
geposted Thu 08 Aug 24 @ 9:58 pm
