Hi.
I prep music / set ideas on my PC then copy my VDJ installation to my laptop to play out.
Ive set low performance options on the PC because stems my laptop isnt as powerful as PC.
A couple times now Ive found the settings have somehow changed.
Ive been playing out and theres a big screech through the PA because my laptop is out of RAM or the CPU is at 90%....
So, does VDJ revert settings on new version update maybe?
Thanks
Thanks
geposted Sat 10 Aug 24 @ 9:28 pm
