So I'm having an issue with sending OS2L commands. I have version The Light Controller 9.3.16 installed on my PC and Virtual DJ v2024 b8263 installed on the same PC. In preferences I have virtual DJ enabled, and I also have Bonjour installed on the PC. When I open Virtual DJ then the light program, and I play a song, it sends the BPM with no issues.
Here is the issue: I am assigning an os2l button command on one of my pads, named os2l_button "cocktail". I have also tried: os2l_button 'cocktail' and os2l_button cocktail. The button in my light show is named cocktail (no capital letters are in the name). When I press the pad it does not activate the button. There has got be something simple that I am missing, but I can't figure it out. Any help with this would be greatly appreciated.
Thanks!
Thanks!
geposted Sun 11 Aug 24 @ 3:43 pm
There was a bug recently, update to the current early access as it has been fixed.
geposted Sun 11 Aug 24 @ 4:18 pm
I'm sorry, update Virtual DJ or The Lighting Controller?
geposted Sun 11 Aug 24 @ 4:38 pm
vdj
geposted Sun 11 Aug 24 @ 4:41 pm
Where would I download the latest version? it's not available within the program? How do I update to early access?
Edit: I figured it out, thanks for your help!
geposted Sun 11 Aug 24 @ 4:46 pm
