i just got my premium faders for my Hercules t7 and I'm not sure why its doing this I don't mind if I lose 1% on the right side and the left side of my fader can someone help me
write a script? if I must lose 1% on both left and right then that's fine. (forgive my writing I have a reading disability) I want it to fully fade at 99%
geposted Sun 18 Aug 24 @ 7:38 am
0.0=[1.0,0.0]/0.3=[1.0,0.1]/0.5=[0.8,0.8]/0.7[0.1,1.0/1.0[1.0=[0.0,0.9
im going to try this i just found it and took one point of the right it was [0.0,0.1
geposted Sun 18 Aug 24 @ 9:23 am
ok that didnt work
geposted Sun 18 Aug 24 @ 9:41 am
Try some simpler ones, and work from there
0=[1,0]/0.09=[1,0]/0.1=[1,1]/0.9=[1,1]/0.91=[0,1]/1=[0,1]
Also make sure that your controller doesn't send an updated curve because of a crossfader curve knob
geposted Sun 18 Aug 24 @ 9:48 am
. and also make sure that it is in face a crossfader issue
you can tests that the incoming messages go all the way between 1 and 0 i the mapping window, like show in the last example here:
geposted Sun 18 Aug 24 @ 9:50 am
