My DJ setup was shelved for a long time and have been getting it back up and running. Currently running 2018 v8.3 b4918 and haven't had a chance to read all the change logs and or forums to see if updating that far back is possible.
Is it gonna be safe to just update from this build or do I need to start over?
I'm using a custom skin I made back in 2018 for a three table setup and don't know if that will most likely break on this drastic of an update?!
My current setup works great, but want to see what improvements have been made....hopefully no major downgrades.
geposted Sun 18 Aug 24 @ 5:41 pm
just update, it'll be fine.
geposted Sun 18 Aug 24 @ 5:45 pm
some skins needed to be updated to keep up with changes over the last few years so that 'might' be an issue
but while there's a little learning curve luckily someone has done some great work to help get people adjusted and up to speed with changes. cause Klaus is da man!
VirtualDJ 2024 Changes and New Features:
https://www.youtube.com/watch?v=I_E9F3Sya9E
geposted Sun 18 Aug 24 @ 6:55 pm
