Can someone verify that sending sampler output to "Headphones only"
(from the sampler menu button > audio output > "headphones only" .... or using sampler_output 'headphones' )
does not route the sample audio to the.... Headphone output set, (in the Settings > Audio tab)?
what happens:
the sampler plays with no sound output in the headphones.
Note:
the audio set up works well for pre-listening to tracks w headphones using PFL (or player on the Info panel, etc.)
IE: headphones work well for everything except for the Sampler.
maybe a needed settings change for this to work ?
what happens:
Note:
geposted Fri 23 Aug 24 @ 7:31 pm
