Hi VirtualDJ Team,
I wanted to bring up a small issue I've encountered while managing my play history. When I delete a track from the history, it not only removes the track from the list but also sends it to the recycle bin. While this does work, I believe it could be more user-friendly.
Would it be possible to add a dedicated "Remove from History" option in the context menu when right-clicking a track in the history section? This button could simply remove the track from the current history list without sending it to the recycle bin. Alternatively, modifying the current "Delete" function to not send it to the recycle bin when in this section could also be a solution.
This small change would make managing the history a bit easier, especially for users like me who want to keep their history clean without affecting the files or linked tracks.
Thanks again for considering this suggestion, and I look forward to your continued innovations!
geposted Sun 25 Aug 24 @ 8:47 am
Just press 'delete' on your keyboard should work fine
geposted Sun 25 Aug 24 @ 8:49 am
