hi, something has changed withe way playlists are saved
not saved as m3u anymore, but as vdjfolder file,
so i cant share my playlist with my other virtual players on my other mirror macs
and play playlist i created on other mac
how do i solve it?
tanxx
how do i solve it?
tanxx
geposted Wed 11 Sep 24 @ 10:46 am
Virtual DJ 2024 (build 8000) unified all playlists under the one common folder structure (the structure is now called MyLists, and you can now either have list folders or filter folders - a playlist is now a list folder)
You can still get VirtualDJ to output playlists to the Playlists folder as m3u by enabling the option browserAutoExportM3U if required (all regular lists (VirtualDJ folders) with songs will be exported) or browserShowLegacyM3UPlaylists if you or your tools modify the list as well.
geposted Wed 11 Sep 24 @ 12:11 pm
tanx @djviniltouch
ok so i did what you suggested and i managed exporting the m3u playlists
and iveshared it to my mirrored mac, then placed it into the playlists folder in virtual dj, i opened the virtual dj, but the specific playlists ive placed, could not be seen in the actual virtual dj software, maybe you could suggest me what to do next?
geposted Fri 13 Sep 24 @ 12:24 pm
- Did you enable the same settings in the other Mac?
- Are all of the tracks in the playlist in an external drive? If so, was the external drive connected when you started VirtualDJ on the second computer?
geposted Fri 13 Sep 24 @ 7:29 pm
tanx so much @djvinyltouch i did what you have suggested and it worked
geposted Thu 19 Sep 24 @ 2:24 pm
@djvinyltouch
how can i make virtual dj work with pioneer 3000 cdj's?
geposted Thu 19 Sep 24 @ 2:26 pm
I think @djdad answered your question in the dedicated post you made for it:
https://virtualdj.com/forums/260435/VirtualDJ_Technical_Support/how_can_i_make_virtual_dj___mac_work_with_pioneer_3000_cdj_s_.html
geposted Fri 20 Sep 24 @ 12:22 am
