Topic: New playlists are not saving on the hard drive!
Hi,
If I create a new list (e.g. "test"), I normally must find the test.vdjfolder into "AppData\Local\VirtualDJ\MyLists" right?
If the list is empty, then the "test.vdjfolder" is there indeed. But after I add some tracks, the "test.vdjfolder" disappears from MyLists folder.
Why is this happening? I used to backup MyLists folder to another location, but now the new lists are nowhere to be found into the hard drive.
Virtual DJ 2024 b8308
Any ideas? Thank you.
geposted Sun 06 Oct 24 @ 7:55 pm
Is hotplug enabled for that list and all of the songs contained in that list by chance on one or more external drives?
The hotpug feature aims to keep associated lists with music on externals hot swappable where applicable, and if all of the songs of that list are on externals, then there wouldn't be list entry on the main (OS) drive. You can change this per list from the right-click context menu on the list itself. I think by default all new lists created have hotplug enabled...if you want this not to be the case then you can set disableHotplugForNewLists as true in your options.
Also, to make sure your backup contains all lists regardless of drive you should use the built in create backup feature
Yes, the new lists were saved into the SSD with the music files.
The fix was "disableHotplugForNewLists - > true ".
Now all the lists stays in MyLists folder.
Thank you!!!
