When i use other ring to bend a track it works as i want in the scratch waves = Backwards it slows down and go backward and forward the opposite correct
But if I look at the main waves windows it does the opposite. So if i dont use sound and only look at main waves it moves forward when i use other ring to bend backwards.
How do i change direction?
Can i change so i see the same movement in both fields or if there are a way to change direction does it then change also movement direction in scratch window?
Think I had this problem many years ago and solved it. But have only used scratch window for many years and just started have main waves visible.
geposted Mon 21 Oct 24 @ 3:46 pm
The "main" (horizontal) waveforms, represent the audio moving under the "needle" (white line)
So, when the track plays forward the waveform moves towards the left.
When the track plays backwards the waveform moves towards the right.
So, when a track is playing, if you drag the waveform from center to left, you speed up the track (since that's the forward direction of the waves), while if you drag it from center to right you slow it down.
PS: No you cannot change the direction of main waveforms.
geposted Tue 22 Oct 24 @ 8:49 am
Massive thread on the same subject here: https://virtualdj.com/forums/187263/Wishes_and_new_features/Wave_Form_Display_Direction.html
geposted Tue 22 Oct 24 @ 8:57 am
