Since I had some sound issues on my PC and wanted to fully use stems 2.0, I decided to try switching to a Macbook Air M3. The Macbook really works great with stems, and stems 2.0 is ready literally in couple seconds after loading a track into the deck. I transferred the settings, playlists, and database without any problems, but the mp3 files themselves were more difficult. On my PC, all my music is stored in the "c:/music" and "c:/other" folders. The Macbook doesn't have a "c" drive, and my entire path to the music has changed, so the program can't see the files. I have to manually transfer files from each folder to virtual dj, of which I have a huge number. Is there an easier way?
Unfortunately, I can't load the main folder with all subfolders into the program at once, since the program doesn't see files in the folders
geposted Wed 06 Nov 24 @ 5:26 am
-Create a database backup on the pc
-Copy the files to the mac
-On the mac, restore the database backup made on the pc
-Recurse or add to search db the new music folder on the mac
geposted Wed 06 Nov 24 @ 5:31 am
Thank you!
geposted Wed 06 Nov 24 @ 6:06 am
