Thank you for your time -
I recently updated from Version 2020 (unknown rev) to Version 2024 b8350. Since doing so, custom keyboard mapping is not functioning. I went into the page, it shows the mappings, ie: I had "P" programmed to activate Prelisten and "A" is programmed to Add Track to Automix, etc. If I go into the keyboard mapping page, it still shows those keys as mapped, however, they no longer respond. I"ve searched the forums as well as the settings to see if there was something I was missing, a new setting, but have found nothing. Hoping it's an easy fix to restore.
geposted Tue 12 Nov 24 @ 5:29 am
Is ALT key mapped to keyboard_shortcuts if so unmap it
geposted Tue 12 Nov 24 @ 5:52 am
Thank you for your response.
ALT key is not mapped to anything.
FWIW I"m running Windows 10 - 64 bit, 64 GB Ram
geposted Wed 13 Nov 24 @ 3:06 am
geposted Wed 13 Nov 24 @ 3:08 am
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<mapper device="KEYBOARD" author="Atomix Productions" version="850" date="2024-11-11">
<map value="TAB" action="deck active select"/>
<map value="CTRL+TAB" action="sideview +1"/>
<map value="CTRL+SHIFT+TAB" action="sideview -1"/>
<map value="SPACE" action="play_pause"/>
<map value="SHIFT+SPACE" action="sync"/>
<map value="CTRL+SPACE" action="automix"/>
<map value="NUM-" action="pitch -0.05"/>
<map value="NUM+" action="pitch +0.05"/>
<map value="SHIFT+NUM-" action="pitch -0.01"/>
<map value="SHIFT+NUM+" action="pitch +0.01"/>
<map value="CTRL+NUM-" action="pitch -0.2"/>
<map value="CTRL+NUM+" action="pitch +0.2"/>
<map value="NUM*" action="pitch 100%"/>
<map value="CTRL+NUM*" action="pitch_reset"/>
<map value="LEFT" action="deck 1 play_button"/>
<map value="RIGHT" action="deck 2 play_button"/>
<map value="SHIFT+LEFT" action="pitch_bend +5%"/>
<map value="SHIFT+RIGHT" action="pitch_bend -5%"/>
<map value="PAGE.DOWN" action="crossfader -10%"/>
<map value="PAGE.UP" action="crossfader +10%"/>
<map value="CTRL+PAGE.DOWN" action="crossfader 0%"/>
<map value="CTRL+PAGE.UP" action="crossfader 100%"/>
<map value="ESCAPE" action="loop"/>
<map value="SHIFT+ESCAPE" action="settings"/>
<map value="1" action="loop 1"/>
<map value="2" action="loop 2"/>
<map value="3" action="nothing"/>
<map value="4" action="loop 4"/>
<map value="5" action="loop 8"/>
<map value="6" action="loop 16"/>
<map value="7" action="loop 32"/>
<map value="8" action="loop_half"/>
<map value="9" action="loop_double"/>
<map value="0" action="reloop"/>
<map value="ALT+1" action="goto_cue 1"/>
<map value="ALT+2" action="goto_cue 2"/>
<map value="ALT+3" action="goto_cue 3"/>
<map value="ALT+4" action="goto_cue 4"/>
<map value="ALT+5" action="goto_cue 5"/>
<map value="ALT+6" action="goto_cue 6"/>
<map value="ALT+7" action="goto_cue 7"/>
<map value="ALT+8" action="goto_cue 8"/>
<map value="ALT+9" action="goto_cue 9"/>
<map value="ALT+0" action="goto_cue 10"/>
<map value="CTRL+1" action="set_cue 1"/>
<map value="CTRL+2" action="set_cue 2"/>
<map value="CTRL+3" action="set_cue 3"/>
<map value="CTRL+4" action="set_cue 4"/>
<map value="CTRL+5" action="set_cue 5"/>
<map value="CTRL+6" action="set_cue 6"/>
<map value="CTRL+7" action="set_cue 7"/>
<map value="CTRL+8" action="set_cue 8"/>
<map value="CTRL+9" action="set_cue 9"/>
<map value="CTRL+0" action="set_cue 10"/>
<map value="F1" action="sampler 1 play_stop"/>
<map value="F2" action="sampler 2 play_stop"/>
<map value="F3" action="sampler 3 play_stop"/>
<map value="F4" action="sampler 4 play_stop"/>
<map value="F5" action="sampler 5 play_stop"/>
<map value="F6" action="sampler 6 play_stop"/>
<map value="F7" action="sampler 7 play_stop"/>
<map value="F8" action="sampler 8 play_stop"/>
<map value="F9" action="sampler 9 play_stop"/>
<map value="F10" action="sampler 10 play_stop"/>
<map value="F11" action="sampler 11 play_stop"/>
<map value="F12" action="sampler 12 play_stop"/>
<map value="SHIFT+F1" action="sampler 1 play while_pressed"/>
<map value="SHIFT+F2" action="sampler 2 play while_pressed"/>
<map value="SHIFT+F3" action="sampler 3 play while_pressed"/>
<map value="SHIFT+F4" action="sampler 4 play while_pressed"/>
<map value="SHIFT+F5" action="sampler 5 play while_pressed"/>
<map value="SHIFT+F6" action="sampler 6 play while_pressed"/>
<map value="SHIFT+F7" action="sampler 7 play while_pressed"/>
<map value="SHIFT+F8" action="sampler 8 play while_pressed"/>
<map value="SHIFT+F9" action="sampler 9 play while_pressed"/>
<map value="SHIFT+F10" action="sampler 10 play while_pressed"/>
<map value="SHIFT+F11" action="sampler 11 play while_pressed"/>
<map value="SHIFT+F12" action="sampler 12 play while_pressed"/>
<map value="P" action="prelisten"/>
<map value="SHIFT+P" action="play while_pressed"/>
<map value="S" action="sandbox"/>
<map value="C" action="cue_stop"/>
<map value="CTRL+F" action="search"/>
<map value="CTRL+BACK" action="goto_last_folder"/>
<map value="CTRL+V" action="video"/>
<map value="M" action="automix_skip"/>
<map value="N" action="automix_skip"/>
<map value="V" action="custom_button 4"/>
<map value="I" action="custom_button 3"/>
<map value="B" action="effect_active 1"/>
<map value="E" action="effect_active 2"/>
<map value="D" action="effect_active 3"/>
<map value="NUM." action="sampler_stop all"/>
<map value="A" action="playlist_add"/>
<map value="CTRL+S" action="playlist_save"/>
<map value="DOWN" action="nudge -10ms"/>
<map value="UP" action="nudge +10ms"/>
<map value="CTRL+LEFT" action="deck 1 cue_stop"/>
<map value="CTRL+RIGHT" action="deck 2 cue_stop"/>
<map value="L" action="pitch_lock"/>
<map value="ONSONGLOAD" action="beatlock off"/>
<map value="CTRL+D" action="browser_gotofolder "filters://Duplicates.vdjfolder\0"/>
</mapper>
</mapper>
geposted Wed 13 Nov 24 @ 3:35 am
Found a solution!
Options>Browser>SearchByFirstLetter set to NO
Fixed and all my mappings work again!
Thanks to Kay Xam [Dr. Scratch] on YouTube for the fix!
https://www.youtube.com/watch?v=54dXO4W-oLU&t=103s
geposted Wed 13 Nov 24 @ 5:14 am
