Hi,
is there a way to to move for example square in video skin? I want to do something similar like old Titler (yellow one) does, slide a background from left to center.
Thank you, did not find anything in VDJwiki and can't find this titler anymore to read his xml file.
geposted Tue 26 Nov 24 @ 1:01 pm
The "yellow titler" is built in to VDJ. Title in the Overlays section of Master FX.
geposted Tue 26 Nov 24 @ 1:37 pm
Do you mean that
https://de.virtualdj.com/plugins/index.html?addonid=80894
geposted Tue 26 Nov 24 @ 2:03 pm
Benz Werner wrote :
Do you mean that
Yes
geposted Tue 26 Nov 24 @ 2:18 pm
Thank you, any way to find its xml?
geposted Tue 26 Nov 24 @ 2:47 pm
It's embedded, so it doesn't have an XML.
My guess is you'd have to use <slider> somehow.
geposted Tue 26 Nov 24 @ 2:56 pm
in that case only Locodog can maybe help
geposted Tue 26 Nov 24 @ 3:35 pm
I'm sure there others xD,
You can animate as an end result, but there's only a few things that can actually move so you have to get creative.
I've got a "totally over the top animated" strip club video skin that I keep doing bits on, but until I have somebody I can sell it to, my interest is on & off.
One early quick example, fade in a square, make it bigger, move it, fade in some text. fade out
The "square" is actually a few faders from horizontal sliders, stuff appears and disappears but it's all on top of each other so it looks like 1 thing.
geposted Tue 26 Nov 24 @ 9:03 pm
locoDog wrote :
Thank you for clarifying this for me.
But how the tilter is working?
geposted Tue 26 Nov 24 @ 10:13 pm
Don't know for sure, probably talking directly to directX/metal, maybe there's an abstraction level so dev can compose in html/css.
geposted Tue 26 Nov 24 @ 10:22 pm
That would be great.
geposted Wed 27 Nov 24 @ 6:19 pm
(Master Video)
Is there a way to Display the "Title" when you have a SAMPLER activated ?
I have a "Name That Tune" video that I activate during the game and I like to display the "TITLE" when they name the song correctly.
I tried but it does not display the "TITLE" when ANY SAMPLER is activated.
geposted Wed 27 Nov 24 @ 10:12 pm
yeah can be done, you have a panel that has visibility depending on a var, usually var if off [so no panel] when you've been given an answer, you press the button and panel appears.
What skin are you baking it into?
realistically you could do it with text plugin but it might look a bit lame.
geposted Thu 28 Nov 24 @ 12:49 am
I'm using Silversleek 3.4 Skin
THanks Locodog for the reply but don't understand what you mean.
Here is a small video.
https://1drv.ms/v/c/fe5b78cb890f81d6/EXVUOZtnyXtPrfo1hqwRwrgBbJRPmVgKvxaXLSSxsdIvuA?e=dttRvA
Thanks
Thanks
geposted Thu 28 Nov 24 @ 1:20 am
Needs a video skin I mean. I don't think title plugin works on sampler,
Not all that complicated a skin but depends on how you want to transition, fade, slide in, grow, shrink, a bit of all 3, there are choices.
geposted Thu 28 Nov 24 @ 1:46 am
