Hello everyone, first thanks for everyone contributing. This is my go to for any problem I have. But i have not found much on the out ring.
My Pitch slider is not working and will not be able to fix it anytime soon. The current mapping on my Pioneer DDJ-SX2 allows me to adjust BPM using shift + the jog wheel out ring. I am trying to increase the sensitivity so i can make small adjustments. Currently, it seems i have to jump BPM or move the out ring fast to get it to register and then it just jumps more BPM's them i am wanting.
Anyone know how to map or make that adjustment?
geposted Thu 05 Dec 24 @ 3:02 pm
whatever your script is [usually helps to say], start with
param_multiply 0.1 &
or you could map the flip buttons to control pitch.
geposted Thu 05 Dec 24 @ 4:00 pm
Thanks for the response LocoDog.
Gave me an idea that I could remap my 3rd FX knob to use as pitch. Thanks.
geposted Fri 06 Dec 24 @ 5:29 pm
