Hi i bought a new macbook and i install the vdj with all the settings copy from my old macbook but at pitch quality i have only 3 options like the old years.0-1-2. i lost the 3 and 4.Please someone to help me what happened?
geposted Sat 07 Dec 24 @ 6:07 am
You can just type 4 manually
geposted Sat 07 Dec 24 @ 6:41 am
Yes i did it and i understand the difference at quality but why down at the description writes only about 0-1-2?It is a bug?I install and olders versions of vdj but nothing changed.Maybe it is a bug because i have macos sequoia?
geposted Sat 07 Dec 24 @ 7:03 am
You did download the latest version from https://virtualdj.com/download/ ?
geposted Sat 07 Dec 24 @ 8:11 am
Yes i have the latest now and i tested and olders but nothing changed
geposted Sat 07 Dec 24 @ 2:56 pm
what are you expecting to change just to be clear?
the text circled in red only appears when you mouse over pitch quality
geposted Sat 07 Dec 24 @ 3:00 pm
The text on me says about 0 1 and 2 pitch quality.No for 3 and 4.Thats my problem.
geposted Sat 07 Dec 24 @ 3:11 pm
Your picture is a bit blurry, but to confirm, the version on the left-bottom says b8472?
geposted Sat 07 Dec 24 @ 3:17 pm
Yes the latest.And i test and olders.I will try a clear photo
geposted Sat 07 Dec 24 @ 3:19 pm
It doesn't matter what it says, 3 & 4 are valid settings.
geposted Sat 07 Dec 24 @ 3:22 pm
It kind of matters since if it's not saying 3 & 4 then it's either an old build that may not support these modes yet, or a custom language file being used. (Check for language files in your virtualdj folder)
geposted Sat 07 Dec 24 @ 3:24 pm
Look now
geposted Sat 07 Dec 24 @ 3:29 pm
It appears that you use the Greek Language option, but the tooltip at the bottom is in Greek.
Do you have any Greek .XML file in /Languages folder ?
If so, delete it and restart VDJ.
geposted Sat 07 Dec 24 @ 4:17 pm
You are perfect its ok now!Thanks 🙏
geposted Sat 07 Dec 24 @ 4:22 pm
