i have been able to figure out the browser but i can not find a way to have a floating scratch wave window to put on my second external monitor.. i searched on the forum but the codes listed leave me with a full screen black window.. any help is greatly appreciated
geposted Sun 12 Jan 25 @ 6:55 am
im using the haunting pro skin
geposted Sun 12 Jan 25 @ 5:25 pm
maticlee wrote :
the codes listed
What code did you use?
geposted Sun 12 Jan 25 @ 5:29 pm
<window name="myWindow" width="1920" height="1080" posx="0" posy="0" image="2 Decks.png" shown="false">
<scratchwave deck="left" orientation="horizontal" colorHigh="colorHigh" colorMed="colorMed" colorBass="colorBass">
<pos x="2" y="2+5"/>
<size width="1900-4" height="56-10"/>
<grid mirrored="yes" pos="-5" shapepos="-5" shapemirrored="both" background="no" backgroundshaded="no" maincolor="textcolor" color="gridcolor" height="5" size="3" mainsize="5" />
<cue y="-3" height="56-10+6">
<text dx="15" dy="-1" size="14" />
<mask width="16" height="56-10+6" x="1570" y="43"/>
</cue>
<gridlines width="1" color="gridcolor" transparency="0.6"/>
<overlay>
<size width="2" height="56"/>
<pos x="+950-2" y="-5"/>
<background shape="square" color="waveneedle" />
</overlay>
</scratchwave>
<scratchwave deck="right" orientation="horizontal" colorVocal="#075CDB" colorInstru="#0CFF00" colorBeat="#FFFFFF" colorNoVocal="#36393B" colorNoInstru="#4B4C4D" colorNoBeat="#595A5C">
<pos x="2" y="2+56+5"/>
<grid pos="-5" mirrored="yes" shapepos="-5" shapemirrored="both" background="no" backgroundshaded="no" maincolor="textcolor" color="gridcolor" height="5" size="3" mainsize="5" />
</cue>
<overlay>
</overlay>
</scratchwave>
</window>
</cue>
<overlay>
</overlay>
</scratchwave>
</cue>
<overlay>
</overlay>
</scratchwave>
</window>
geposted Sun 12 Jan 25 @ 9:50 pm
You've extracted that from an existing skin?
I'm asking as the colours have names, like 'waveneedle' and 'gridcolor' but those names have not been defined (definitions are usually earlier in the skin).
E.G.
You can substitute actual colors instead, either with obvious names, or with codes (as you can see in some cases i.e. #4B4C4D)
E.G.
<group name="nameofgroup">
<define color="waveneedle" value="#e3e3e3"/>
<define color="gridcolor" value="#0a0b0d"/>
</group>
geposted Mon 13 Jan 25 @ 6:21 pm
Hi,
Look at my forum thread, this explain everything about this subject.
https://virtualdj.com/forums/261194/VirtualDJ_Skins/Panel_in_floating_window.html
Gr Marcel
Gr Marcel
geposted Mon 13 Jan 25 @ 7:22 pm
I guess as it's a window, it takes the defines from the main skin? Can't remember...
geposted Mon 13 Jan 25 @ 7:52 pm
it was a code listed when searched the forums for floating window and stumbled across the thread showing this code i believe its from the thread in the link posted above
geposted Mon 13 Jan 25 @ 9:32 pm
Ah OK so you're using Haunting Pro, but he was using the Blocks skin I believe - which means that (as I said earlier) the colour references don't match up.
The colours mentioned in that excerpt will be defined in the Blocks skin, so don't match with the definitions in Haunting Pro.
geposted Mon 13 Jan 25 @ 9:51 pm
AHHH OK I SEE!!!! i will attempt it again and i will report back thanks!
geposted Tue 14 Jan 25 @ 12:14 am
