Will there be any future support for phase HID for 4 decks?
I am having a really hard time keeping even 2 decks to stay sync in DVS and 4 is pretty much useless with my current workflow, even with auto sync enabled.
Do I need to consider digital players, is there a workaround or can we expect an HID 4 deck update?
geposted Mon 20 Jan 25 @ 2:46 pm
So this is controlles by leftdeck/rightdeck selection...like you should be able to control deck 3 with the left remove by doing the following?
deck 3 leftdeck
Deck 4 and the rightdeck would be similar
This one is hard in general to do because of the nature of turntables. You might get better results by introducing beatlock into the mix, and potentially even deactivating timecode processing (timecode_active off) for DVS mode and disabling Vinyl Mode for HID mode, to allow for the decks to function in fully internal mode (it will definitely have no fluctuatuons then) while doing the transitions needing sync.
However, once those processings are on, the turntable specs for wow and flutter would take over and complicat the matter.
See the first answer 🍺
geposted Mon 20 Jan 25 @ 5:37 pm
